fox_forma
Need some opinions if possible. I was originally planning a single 12" set up for my silverado ex cab but came across a few deals. If I go with a single sub I would need a single 4ohm or dual two as my amp runs 800wrms @ 4ohms. The SSi is only a 10" dual 2ohm and my amp would power it pretty good (its a cadence z9000) I have a box right now built for under the seat that is 2.2cuft without any ports added in yet. I had intended on porting it and going with one 12" sub but would this box be to big for the 10" SSi? Another option is to go with two TSX 12's that are dual 4ohms and run them in the current box sealed which should give them the required airspace needed for a sealed enclosure. I listen to rap and rock/metal mostly but only turn the system on for the rap and certain metal songs that have a nice kick to them.
Thanks
Thanks
