Single Din Headunit - Nothing fancy
  • 4
2000Gator
Hey Guys, just looking for a basic single din headunit to go in my car. Nothing fancy, but would like it to come with all accessories from new and to function/look 100%. Would prefer Kenwood, Pioneer, Alpine. Aux/usb preferably as well. Would like to spend under $100.
What type of car is this going into?
I can do my Kenwood KMM-308 (has front USB and AUX, 1 set of Pre-amp outputs) which is still NIB with installation parts for $65 shipped. if you want me to solder the harness for you, I can do that for an additional $5. so $65 for the radio and installation parts. $70 for radio, installation parts, and soldered harness.
Is the full part # kmm-BT308u? I don't see just a kmm-308 out there. Are you including the dash kit as well? Will the terminations be soldered and heat shrinked?
The 2000 Corolla is a single din set up so it would just the headunit only with no extra pocket. If you're including that I will purchase the headunit. To confirm it's $70 for NIB headunit with all accessories, wiring harness soldered, and install/dash kit correct? If this is right either pm or post your paypal and i'll get the $70 to you.
PM'd
657
Check each speaker for shorts. A pinched wire grounding out or a individual blown speaker can sometimes make the internal amp go into protection.
2000Gator
2000Gator
Baltimore, MD
fasfocus00
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
