Single capable amp needed to push 2 12" bone crushers.
I have a broken windscreen, visors are falling out... window switch panel comes loose constantly and the metal around the drivers door striker is torn and I've had to reattach the hasp to the rear gate window several times... the passenger door handle was loose and falling out at one point... and my rearview mirror is non-existent (it broke in half)... the side mirrors adjustments have come loose and they move ALOT... vents on dash are falling apart and dash is cracking as well... oh well... it's a little rowdy inside... I'd like to tune/play with your setup... but it is in AUS...
I have a broken windscreen, visors are falling out... window switch panel comes loose constantly and the metal around the drivers door striker is torn and I've had to reattach the hasp to the rear gate window several times... the passenger door handle was loose and falling out at one point... and my rearview mirror is non-existant... the side mirrors adjustments have come loose and they move ALOT... vents on dash are falling apart and dash is cracking as well... oh well... it's a little rowdy inside... I'd like to tune/play with your setup... but it is in AUS...
I'v followed a very strict frequency guidelines I'v set myself.. Just tuned all the speaker intune with HU frequency. The sub no longer plays through an entire song (enable infrasonic it is advised in vented closures an limits the sub to no higher than 28hz) speaker can handle much much more at a higher volume with no distortion. Hope I'm improving here...
Sent from my MHA-L09 using Tapatalk
That made me confused... I'm sorry...
If you want help with settings I can try... usually I avoid this part... lol
On the head unit be sure the bass/treble is off..(flat).. no loudness either... the sub level adjustment should be basically centered so you can boost or cut level for different music... your head unit will probably distort at 3/4 volume so keep that in mind and set that volume as your max... (IE... 28 out of 35 max)... never boost your bass with a remote just set your lowpass between 60-80 hz to your taste... turn down any bass boost the amp has... if you have a remote gain for the amp... center it before setting levels... it affords the boost/cut you'll need without using bass boost... I can't say that enough... OK?...set your Subsonic filter at 26 hz or so and you should be OK... check each step with an O-scope to be sure...set it on A/C voltage and watch the waveform for clipping... a barely clipped signal is ok but remember not all music is recorded the same and a louder one WILL clip the signal and probably cause problems.... I Obviously I cannot do it for you, and I probably missed a few things but watch a few vids and reread this and you'll be golden
I listen to RAP RNB and HOUSE. The occasional soul here n there
I haven't changed my HU yet so I Dnt have that wave feature... I went through a few threads an come across the clarion Nx706.... It retails at $1000AUD..what do you know Abt the HU.
so that low tuning is perfect for you... imagine even MORE lows... lol... a bigger box designed correctly will KILL the lows...
If you ever find some more room those subs or any subs for that matter will do much better in a larger box... let me know...
This car is going to my Mrs my next car will have a much bigger boot that's for sure but yes I will let you know.
Wave feature?
Wellyboy
Wellyboy
AU
Wellyboy
