single cab yota build
  • 5
ballin123491876
moneta,va
so i'm putting two 10'' memphis pr's in a toyota,running them off a memphis pr 500.1, i have pretty much figured out the box size and everything but i am just wondering if .6 cubes a sub(after displacement) ported tuned to 40 hz is enough airspace?
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
Hello, What amps should I use for this: 2xFocal Auditor Sub 12 Slim Focal Expert PS165v1 Can Focal FPX 5.1200 work or is too much?
Well the setup I mentioned cost around 1,000 USD in my country and an extra 500 USD for the DPS. HU? The car display? I plan to stay with original
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
654
ballin123491876
ballin123491876
moneta,va
Mattd0344
