BIG-SMOOTH
I'm pretty well set on running a pair of SS Rli-8's for my substage, but I want to see if there are any single 12" subs out there that fit my criteria that may be worth looking into. I will be running the sub(s) off a Rockford punch150. I haven't received the amp yet, but the birthsheets I've seen from other owners tend to run in the 900-1000 watt range when bridged into a mono 4 ohm load. This will be going in a standard cab silverado and I'm 6'7" and I frequently carry passengers over 6' so the seats are not going to be able to be moved very far. Here's what I'm looking for...
either dual 2 ohm or single 4 ohm
works well in an enclosure size of 1.25^ft or smaller (sealed)
maximum mounting depth of 6"
run well off of 900-1000 watts
priced under $400
I'm going for a daily driver setup. I want something that will get reasonably loud, but my main concern is for sound quality. I listen to mostly punk/metal/rock with some rap on occasion.
I haven't found much that meets all my criteria so if you guys know of anything that will work for me and be comparable to a pair of 8" rli's in both SQ and SPL I'm all ears.
priced under $400
