Simple Wiring Question...
BDIDDY
Sittin' Slick
I had my B12 wired to 4 ohms, parallel or in series which ever, and I was told at a comp. that if I connect all of my positives together and put them in the positive terminal, then connect all of my negatives together and put them in the negative terminal that I would have a 1 ohm load. I have 2 positives and 2 negatives running out of my box..
Any help would be appreciated...
Well I have been misinforming everyone then. I had my MTX 81000d running at 1 ohm, daily...
What do you think the 1000d could push out @ 1 ohm with a stock charging system?...
Thanks alot for the help...
depends on what your ALT amperage rating is at plus it also depends on voltage drop due to wiring sizes and fusing... it depends on a lot of things, u would neeed to tell us all the info possible, including what you battery's voltage is rated at idle and when the car is on...
BDIDDY
Sittin' Slick
BDIDDY
Tennessee
MTX BUMPA
vegang
vegang
