simple question
DJ^
my set up
1 DC power 270 xp (200 amp idle- 270 peak)
1 RF Power t 1500 (manual says fuse should be 200 amps)
2 RF t1's
i have a 200 amp circuit breaker, and when in twards the top end (27/32) is about the volume it will trip
wondering if its ok just to run a 300 amp monster ANL fuse it keep that **** from popping, or is that to much current for my amp ?
amp is not fused as far as i know, never had thermal light come on, and its never felt hot, its grounded to my seat bracket, i actually pulled it off and wire wheeled the paint off, as well and the nut that had some corrosion, put the seat bracket back over the bolt, greased it and tighted, its hooked up with a copper lug, so as far as i can tell im just drawing more than 200 amps, but i dont understand why my amp fuse would be rated at 200 then ?
also, no i dont have anymore batterys, i have one optimia yellow top up front, im gonna get a kinetik 16v 3 terminal in the near furture
the gain is not a volume knob. Depending on how many volts your HU puts out and how high you have it turned up.
Either you have a bunk breaker or your likely clipping which will kill your subs
DJ^
DJ^
Brigham City, UT
DJ^
