simple question
those amps do way more than 250rms... If the amps are strapable you coul strap them and wire the 2 subs in parallel to get 4ohms... but i don't know if this can be done with those amps.
They aren't strappable.
rocafella ~ unfortunately the voice coil configuration on those subs just isn't particularly suitable for those amps. You'd likely be better off getting a different amp that does the power that you need @ 4 Ohms (wire both subs in parallel to achieve a 4 Ohm nominal load)
Hate to say it, playa, but that's the long and short of it. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
rocafella1
rocafella1
saint paul mn
squeak9798
BP1Fanatic
BP1Fanatic
