Simple notch filter to kill off peak?
  • 2
ancorp
Toronto
So it seems no matter what setup I have in my car, it always tends to peak a bit at 40-45hz.
Is there any simple way to lower the signal in that region without affecting above 45ish, and below 38-40? Without having some really expensive sound processor.
My deck is the Pioneer DEH-6000UB
Lows amp is Clarion DPX11500
Subs - two JL 12W6V2
Box - 4CU@32Hz with 64" port area, firing into the car. Even when I had it not sealed off and firing towards the trunk lid I had that peak, same with a previous setup (DD 2515 on Kaption D1000.1) and the one before that.
I went with those simply because they fit, the cutout is round, and the hole will take a 6.5 coax. Cutting a square hole in a boat for a speaker...
21
5K
I think you're going to find this is true across the board. Technology has come so far at this point that even the absolute rock bottom unit that...
I would run a pair of 15s in an suv.. or run 4) 12s
24
No Issues out of my CT Sounds amps..EQ, 6.5s. There is not one company out there that hast ever had a perfect QC run that I can think of.Hard to...
ancorp
ancorp
Toronto
Kangaroux
Decebal
    Jun 10, 2024
