speakerdude123
How much of a difference does the signal to noise ratio (dB) make on an amplifier. I see some with 70dB and others at like 110dB?
IDK, the 13w6v2 loaded JL Audio Stealthbox in my Mustang has a pretty flat transfer rate in that particular vehicle. There are very few after market options that came anywhere near flat.ever thought that if you had the best sq sub not sure of which that is but would you then notice a difference lol.
That was the major PROBLEM with old school measurements because companies didn't disclose how their rated specs were measured. Orion, for example, was guilty of rating their damping factor at the circuit board versus the molex plug and those were significantly different numbers! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Also, I just picked Orion as an example BUT they are not the only old school company guilty of doing this back in the day!IIRC the old school companies that actually made good amps rated s/n referenced to 1W. Its only be more recently that noise to rated output has been used to inflate the numbers.
As previously mentioned though, s/n isn't a spec I'd give much weight to for a sub amp unless it was just insanely low compared to 1w.
