Quick question. I'm thinking of replacing the two re xxx's I have with two Id Max to get a little more on the sq side. I am currently running the re's at 1 ohm on the orion 2500d. If I get Id maxes should I wire the amp at 1ohm or 2 ohms. The orion does:
1700@2ohm, and 2500@1ohm. I heard Id's can't take over 1 thousand watts/sub so I'm probably risking it with 2500. There is also the question of a better damping factor at 2ohms, will I notice it?
