Shop tool essentials
For a woodworking shop I'd have the following....
Table saw
Circular saw
Jig saw
Router and table
sanders (palm, belt)
Cordless drill
Drill press
Scroll saw (not neccesary but are nice to have)
Thats just a couple things that I can think of off the top of my head. I'm sure other ppl will post up some that I forgot.
Jon
Metric nut drivers and allen wrenches. Torx bits, sockets, various screwdriver bits, one of those screwdriver attachments for the drill with the sleeve that covers the screws- keeps you from porting woofers. Putty knives, panel poppers, assorted wire strippers, wire cutters (big and small) soldering iron & solder, straight and 90 degree picks, ford keys, euro keys, DMM, air compressor and attachments, jump starter, a full set of screw drivers, heat gun, strip caulk, grommets, abs plastic...
... just to name a few
nice set, get some big limb cutters to cut big wire, i have a set with long handles on them, slices through 1/0 like nothing
dont get cheap wire strippers or cutters either, nothing pissed me off more thant that when working on the system
also grab a razor or one of the razor blade pocket knives
Drill press
band saw
a GOOD air compressor. Look elsewhere than HD for the compressor. Plan on paying a good bit for one, but you will thank yourself. Air tools you can do on the relative cheap but the compressor...
lots of different clamps
a couple of good cordless drills
spare batteries for the above
a good corded drill
If you want to get serious...
table mounted drum sander
bench grinder (get a polishing wheel for it or another one just for polishing)
bench mount disc/belt sander
good blades for all the saws
good drill bits
good router bits
dust collection system
shop vac
Lowe's now offers a portable compressor system that uses refillable CO2 tanks. It looks pretty nifty. The larger container can shoot ~500 staples. The replacement containers are ~$35 IIRC
Cost of kit is $99.00. It looks good for a place that didn't have the room for a compressor. A real compressor is a lot better.
Radioflyer97
C.E.O.
Radioflyer97
earth (for the moment)
dspencer24
