Shhhhh sound from my headunit.
ok... one more time for those of you who didn't read the first post. it makes the same noise without the amps... it's just less of a noise because there is less power.
are you doing the right frequency filter for your tweeter?
well then i assume it's a bad ground or you have a bad head unit or the other likely answer is that you have songs recorded with +db or with too much distortion or with very low quality causing the ground noise...
anyways, test your comps on another head unit, see if it still occurs
jimmclrk1
Weh mah Savage?
jimmclrk1
The charming city of Atlanta
Slaugh
