Sharp Bass?
I've heard several R set ups and sharp was never a word that came to mind. boomy/muddy would be a better description.
I run a 15" Q in the GF's Cobalt in a ported box tuned to 32Hz and it's quite punchy on metal/rock and pounds the lows on rap...
Any suggestions?I am not going to spend tooo much money on this set up. Because i just want something simple.
I drive a Copalt SS so the car isnt that big at all.
Suggestions?
I recall talking to you about the car in your build thread. Are you concerned with weight? By "sharp," do you mean tight, well-defined bass?
If the answer to both questions is a yes, I'd suggest the following:
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17264
This driver does very well in a ~1.2ft3 sealed or 1.5ft3 ported enclosure. It's extremely sensitive, more than its specs suggest, so you can use a relatively small amp. I preferred its performance to an IDQ12V2. If you're looking for a delineated low end with impressive dynamic drive on a budget, this is it. As a bonus, the sub weighs ~30-40lbs with enclosure, depending.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-555
This is also a sensitive, very good sounding driver that does well in a 1ft3 sealed enclosure. Essentially, everything said above applies here, albeit without as much of a (sonic) kick in the ***. Good luck.
its obvious guys
my shit is so sharp it'll cut you //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
but for real, for it being ported it's super tight, and clean. even double kicks are awesome and handled really well.
Mazdaboi318
Mazdaboi318
Bossier
microhaxo
