Settings on 5 channel amp.
Ive been looking for a good tutorial on the proper way to set 4 and 5 channel amps can anyone link me something or break this down? I just need a basic guideline to follow without Oscope.
1) Do the same rules apply using multi meter to set gain on 4chan as a mono? what test tone to use? How?
2) setting HPF / LPF on 4 chan and one mono
What head unit are you running? What equipment do you have? Setting it up is based on what you can do
Current settings
Mono LPF @ 80hz ---> deck is set same
mono gain set by multimeter
5channel amp = HPF for component set @ 80hz ---> deck is set to 80hz / -6db
5channel amp = HPS 3.5 tweeters set @ 125hz ---> deck is set to 125hz / -6db
5channel amp gain is set to as close to 4v as possible without multimeter. *there is no distortion, not to my deaf ears at least*
**I smoked the two 1" tweeters, waiting on replacements. that was prior to the settings I just posted. it was tuned higher.
[Alternator]
a) Stock Denso 160-amp OEM#421000-7041 *Jonathan Patrick 270amp ordered, waiting for install*
[battery]
a) Duracell Platinum AGM Battery
b) XS-5100
[big 3 Upgrade]
a) 1/0 Ground Block to Chassis.
b) 1/0 Ground Battery Negative to Chassis.
c) 1/0 Positive Battery to Alternator
[Head Unit]
a) Pioneer AVH-2330NEX
b) Axxess ASWC-1 Steering Wheel Control Adapter
c) Metra 40-EU10 Antenna Adapter
d) Metra 99-6525B
[subwoofers]
a) Rival a12.22 12” 2000w RMS Dual 2-Ohm
b) Rival a12.22 12” 2000w RMS Dual 2-Ohm
c) Enclosure FB=39.22 F3=31.66 Ported and Firing to cab.
[Amplifiers]
a) MMats 3000.05
b) Pioneer GM-9605
[Mids and Highs]
a) Pioneer TS-D69C *component set* (110rms)
b) Pioneer TS-B350PRO 3.5 P.R.O Series Bullet Tweeter *pair*
[Misc. Equipment]
a) Stinger SVMB Voltmeter
b) All 10 and/or 8-gauge speaker wire.
c) All 1/0 with minimal 4gauge on amps.
the frequency reposonce for those TS-B350PRO 3,500 Hz to 27 kHz so you should be crossing much higher that 125hz
ill adjust higher and see what happens //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
znewberry
znewberry
Illinois
BOOMINGRANDPA
