Setting gains: before or after setting xove points
  • 4
you want your eq flat, xovers turned off. dont think time align matters. you could try both, see if theres a change voltage wise
So just a quick question. Does it matter if you set your gains before or after you set your xover points? What about time alignment? Should absolutely everything be set to zero or default while setting gains?
Time alignment is set before crossovers. Set crossovers initially to protect the speakers. There's no need to wait to set a subwoofer LPF. Many coaxials, components, and mids in the 6.5" size or larger can handle a High Pass Filter at 80 Hz.
What method will you use to set gains?
I've seen a lot of people using the SMD DD-1 for gains. I've personally never used it, but I may pick one up to fiddle with it. Multimeter has always been my go-to after using an oscilloscope to figure out where the head unit distorts. Most systems in the past I have run the 80PRS which doesn't distort at full volume, though IIRC the full 5v of the preout doesn't hit until 55+
That's nothing but an annoyingly common phrase to try to sound smart. Don't say "gain is not a volume knob" until you can explain how it differs...
10
Sounds like you got it set correctly.
ItsHammer
CarAudio.com Recruit
ItsHammer
Florida
krisfnbz
    May 18, 2024
    May 18, 2024
