Seriously now... IA 20.1 vs. Orion 2500D NO BS
voltages: 12,14,17resistance: 4, 2, 1, .5, .35, .175, .0875(i think the 20.1 can go this low)
How about we don't take my beloved amp to the braking point? k thnx...
Jeebus Dave, it's outta your hands and you want the thing DEAD! //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I'll get with nick on testing values.
oh dont worry, im sure the 20.1 can handle lil o' .08ohms cmon, its a 20.1 for cryin aloud
I'm sure it can, and if you'd like to put your 2500 on the bench for it we can.
What it boils down to is I'd rather not have to get it fixed at all.
shit why don't we just dead short them????? CAUSE WE DON"T NEED TO
It's "modded" right outta the box, and I'd want Incriminator to fix it so it still had a warranty.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
dude, c'mon. you know you want the 1st IA-US Amps hybrid!
that would freakin rock.
a 20.1 with MLT strapping abilities. //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
I assume if you are doing these tests on a bench you will be using a resistive load... if so you wont need to go any lower than 1 ohm on either amp to get full output. FYI you will need a load that can dissipate at least 45 - 50 amp of current for the 2500d and be able to dissipate over 80 amps for the 20.1. If you dont have this ability I would recommend keeping your distance between the resistive load and yourself //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
So... when's the next show?//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
hmmmm its quite a possibility. Ill be the second!!!
i think they have a dual 200A (or was it 400? forgot) power supply over there so we will see what goes down. or blows up
I'd care to wager some money....only way your gonna kill it is if you hook it up to a dead short....or gag the power supply with 24 volts....
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
flakko
Veteran (my butt)
flakko
So Cal
Johnny Drama
