seperating speakers in kickpannels
pwnt by pat
Pat for Prez 2024 - vote!
I'm (finally) finished with the bases for my kicks. It has come time to fleece and construct the tops however I am unsure how to go about seperating the airspace between speakers. I'll be using a 4.5" full range and a 8" so I'll definately need 'em set alone.
Is the best way to make a mdf baffle, trim, screw/fg around, etc? or build a fg wall? Other?
Thanks!
Wow, you are putting an 8" in your kicks with a 4.5"? Thats going to be a huge kick. Anyway, mdf or glass will be fine to seperate them. I would think mdf and glass would be eaiser to work with in there. That way you only have to glass the mdf in rather than building a wall out of glass.
an 8 and a 4.5 in a kick panel? any tweeters? i would've done 8 in a door pod, then 4.5 and tweets in kicks. anyways just build a baffle that has a hole for both speakers.
Yeah, both an 8 and 4.5 in a kick. It doesn't take up that much room despite being in a Golf with a clutch. No, no tweeter because the 4.5 is a fullrange driver and accurately coveres up to 20k with a slight dip at 7khz
Because it'll be easier to aim them with the 4.5's when in the kicks plus if I work on door pods, I'll never NEVER get the doors done. I just don't have time to work on a door where the kicks I can keep 'em out of the car. Weather is also turned sour.
Plus if I get the time/will I'll mod the doors to accept the 10s.
pwnt by pat
pwnt by pat
Pa
pwnt by pat
vegang
vegang
