HardHitter
Alright, well as you know I have a 10W7 that I have for my RX-7, but the setup is just too heavy for me and the trunk of the RX-7 is VERY small so doing a custom setup for it is a PITA so I'm going to sell my 10W7 and go with all eD system or other suggestions.
I already have eDi 6500's, Nine.2, Nine.2x so I'll have 600W @ 4ohms
What I'm looking to get out of the system is ideal SQL. The 10W7 was perfect for the SQ.
I can get 1.52ft^3 BEFORE displacement of sub/port (if I port) and was wondering what kind of setup you guys would suggest.
I've had e15K's before in my blazer (the e cone) and I loved them. I haven't had an eD sub since.
I'm thinking maybe a single 13Ov2 ported, or 11Ov2 ported or sealed/ported 11Kv2 or 9Kv2's or EU-700's the setups are plenty or anything else that's out there.
Not looking to spend more than $250 for subs. The less money the better of course. I would like to get greater SPL than the 10W7 and try to keep the same SQ or close to it.
I'd also like to keep the weight down as far as the system goes. The 10W7 and sealed box were just simply too much weight. If there is any way, I'd like to keep the whole setup as light as possible, meaning I'll probably have to fiberglass rather than MDF setup.
The max dimensions of the box will be
26" long, 18" deep, and 8" high, and the sub(s) will be firing up so the subs cannot be very deep subs.
I like tight bass that hits you in the chest, like kick drums basically, and will blend smoothly with the 6500's. The 10W7 did a great job of doing that, but it seems like it was missing that punch to the chest on quick hits.
I listen to everything except country so the subs are going to have to take on a lot of different kind of music. Needs to be able to hit bass lines for rap, quick hits from rock, and blend well with my fronts for all other types of music.
Thats what the setup looked like temporarily with the 10W7. I was going to build a new box in order to make it fit below the strut bar but it was just too much work, so now I am changing the whole setup so it's all going to lay flat and fire up towards the hatch window like this...
How would this sound firing up though?
Amps will be going along the bottom like they are now and sub(s) will be above it.
