Security Issues
jeeper07
Rebuilding&Reconstruc ting
Ok tryin to figure out how to ensure the saftey of my sub box, sub, and amps? I would just bolt them to the floor but im pretty sure that would hit the gas tank and that would not be good! any ideas cause first of all they slide around and someone could just grab them really easy please help
jeep....? grand? cherokee? wrangler?
either way you should be able to find a spot in any of those vehicles to drill a hole to bolt the box down. for example, in mine i just drilled out the rivits for the 4 cargo hold downs and used those holes to run my bolts through.
some people even buy a steel cable with loop ends, and bolt one end into the box and the other on any major bolt on the vehicle.
Definitely bolt your equipment down, it will help some what. Just remember that if someone wants your stuff bad enough they will get it. Dont forget the tint. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
jeeper07
jeeper07
Indianapolis, IN
John3000
