Sealed enclosure size for 5 1/4 hertz hsk 130 speakers
If you give us the t/s for the drivers and the mathematical transfer function of your car we could let you know the optimal box size.
Expect to build at least 3-4 different enclosures to get that right.
D mm 105
Xmax mm 3
Re Ω 3,1
Fs Hz 80
Le mH@1kHz 0,34
Le mH@10kHz 0,19
Component 2 way system
Size HV 130 woofer 130 (5”1/4)
mm HT 25 tweeter 25 (1”)
Power W peak 200
Handling W continuous 100
Impedance Ω 4
Frequency Hz 60 ÷ 22k
response
Sensitivity dB/SPL 91
Crossover LO/HI-pass 3.2 kHz @
included 12/12 dB OCT.
Component Tweeter -2; 0; +2
adjustment
Outer Ø Woofer 131
mm Tweeter 44
Mounting Ø Woofer 115
mm Tweeter 41
Total depth Woofer 73,5
mm Tweeter 26
Mount. depth Woofer 65
mm Tweeter 15
Magnet size Woofer 85
mm Tweeter 24,5
Weight of one Woofer 1,04
component kg Tweeter 0,06
Voice coil Ø Woofer 25
Vas l 5,00
Mms g 9,5
Cms mm/N 0,45
BL T-m 5,40
Qts 0,50
Qes 0,55
Qms 11,00
Spl (1m/2,83V) dB 91
fatboyracing
fatboyracing
Owensboro KY
fatboyracing
