OCme
Hey all, I ordered two Dayton Audio HF 10" Subwoofers today. I choose the High Fidelity(HF) version over the High Output (HO) because they had better sensitivity making them more musical and just seemed like a solid SQ sub at the price-point of $135.86. They should be fine for the music I enjoy the most which is Oldies Rock and Jazz. I'm not a big fan of Rap or Hip-Hop. I plan on wiring them in Parallel for a 2 ohm load and installing them in a sealed enclosure. Dayton Audio says the optimum cabinet size for a sealed enclosure is 0.53 ft3 volume, but when I used AJ Sealed Designer 2.0 the total volume came out to 439.024, so I'm a little confused. Anyone here have experience with these subs and if so can you recommend what size cabinet I should use? The dimensions for the space I have to work with are D26.5" x W40" x H16-17"
