sealed 10" 800series Alphasonik
SMS
MA
Looking for some help on a size sealed box for an Alphasonik 800series 10", 800W RMS, and displacement of .16. The book says .5-1.25 cu/ft but my local guy says its too small and 2cu/ft would be a minimuim-that seems huge for a sealed 10".
any help would be appreiated .
Yes, I went with his experienced advice and put it in a 2cu sealed box, he tuned my amp for the break-in and it blow in about 15 minutes of moderate volume. It makes a popping sound even at low volumes. I didnt smell anything? I picked it up right when he closed last night and he wont be open till tuesday. I really have no idea what happened?
wonderful. I wanted it in a 1cu box-which the company recomends but he said it wouldnt sound good.
Guess Ill make a smaller box and return it to him.
Thanks for your help
Ported was my intention, I have a 1.35cu ported box that I was going to use. The Alphasonik 2010 book didnt list the box specs so I didnt relize that there minium ported was 2.0cu. I could make one but i was told that a ported box has to be at least 15" depth-front to back, to get 2+cuft my trunk would be useless to family life. I had my 1.35 hinged to swing to the front of the trunk only taking up 11"- nice setup but its .8cuft too small for the sub.
Now my plan is the back seat floor in about 1.15cu sealed. I would much rather have a ported setup.
Yes the manual says 2.0cu is the minimum. Seems really big - what would the disadvantage in using a ported box .65cuft smaller than suggested by manufacture?
It is a pretty big 10- .156 displacement and it weighs about 30lbs or more.
Thanks for any help.
Yes the manual says 2.0cu is the minimum. Seems really big - what would the disadvantage in using a ported box .65cuft smaller than suggested by manufacture?It is a pretty big 10- .156 displacement and it weighs about 30lbs or more.
The question is whether ot not the manufacturer even knows what they're doing. Maybe the 2ft^3 is before sub/port displacement, like I have seen others do.
Good point. Im going to call them tomorrow and talk to there "tech".
Could I blow the sub by having it in a smaller box?
The port is roughly 1.5"-13" slot if that matters.
I notice that you design boxes, how would you go about it with no or false info on the specs?
Thanks again.
Good point. Im going to call them tomorrow and talk to there "tech".Could I blow the sub by having it in a smaller box?
Thanks again.
Without any real t/s specs it's kinda hard, unless you can find other people who have used it. For a normal 10" sub, 1.25-1.5ft^3 with a tuning in the30-33hz range work well, but you never know what this sub mayb really like. Your port area seems fine if you're referring to it being 13" x 1.5" x X" deep.
SMS
SMS
MA
RAM_Designs
