Sealed (1.4 Net) High Output Subs?
Well I really can't decide on what woofers to get now, Before placing my order for two Rl-p 12's i just wanted to make sure that those subs were the ones i wanted. So i did some searching and i found a few threads that said the Rl-p doesnt do so good sealed. So my question is what are some subs that have really good output in 1.4 cubes net sealed off of around 700 watts? *note...mounting depth needs to be no more than 7, maybe 8 inches.
Budget is not an issue.
Thanks, Clif
Is your 1.4 total or for each sub? If you only have 1.4 I would suggest one 12" instead of two. You will gain more more low end extention with the larger box.
The RL-P or SI Mag will perform excellent in a 1.4 sealed box. Definatly with 700rms.
If your strickly wanting output, try a kicker L7 or a pair of Comp VRs Cerwin Vega V-max. But the above subs(rl-p & mag) would/should have close to the same output and excellent tonal quality.
I had a 12" IDMAX in a 1.5 sealed box (I know a tad bigger) and it got AMAZINGLY loud and sounded INCREDIBLE!!
And what is the depth on those smart one? Please read the full thread next time //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Thanks, Clif
Chevyaudio
:poof:
Chevyaudio
Back in the Dirty BR, Louisiana
audioholic
