Seal Boxes have a limit?
I own a CVR12 and I was hoping to get a bigger box , I have them right know on a sealed box that was suggested by Kickers Manual
building a ported box ~2.5 cu ft tuned to 30 hz will make a night and day difference. itll be A lot louder, and smoother if done right, thats what i would do.
how do I know if I'm tuned at 30hz?
I'm sure PETA or Greenpeace wouldn't like that //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
But to answer the original question, when you get to a sealed volume that's four times the Vas of the driver (10x Vas is "ideal", but anything over 4 will work), it's known as 'infinite baffle'. Some drivers (like ID IDW's, for example) are at home in an environment like this; this kind of alignment has a very flat freqeuency response and excellent transient characteristics. Very musical.
However, power handling is reduced and so is overall output...definitely not the way you want to go if you're into daily farting.
thanks jim
So you mean Ported boxes would be much better them a seal box? from your expirience what would you do If you had a CVR12? seal or ported
Octavio
Octavio
Nic
hardhitta47
