DDeitz
So i went to post office and picked up this box. I was pretty happy with it. It was fairly light and could be used as a paper weight or a center piece on my coffee table. But i decided to open it up anyway.
Oh look a box inside of a box so i can box while i box!
And BUBBLE WRAP! this is the best box ever. That is also a team SD sticker and the link cable for linking 2 amps together //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The amp itself
A butt shot of the net\pos terminals.
This is the SD8000 Next to an autotek mm4000.1D it makes 4kw at 2ohms and weights atleast twice as much as the SD8000 it is also quite a bit longer i would guess 6-7 inches. (higher res)
And heres the guts (higher res)
The amp as you can see is no bullshit at all, everything is close together and made for performance. Its also very light compared to other large amps.
The amp itself
