Autotek MM4000.1 ?'s
Andrew12
Honda.
This is geared towards those who have ran this amplifier before. I'm just curious as to the electrical setup you were using when running this amp. I remember reading somewhere about a guy running this amp at 2ohm and only having a Stinger SPV 35 up front and an SPV 70 in the rear on his stock Acura tsx alternator. Just curious on the efficiency of this amp for daily use.
I was planning on selling this and grabbing an AQ 3500, but from the little extra research I've done on these amps, I think I may keep it and use it to murder my stock 99' civic alt. //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
Looking forward to your feedback.
Thanks
Andrew
I ran 1 on a Kinetik 800 under the hood, 2 kinetik 2400's in the back, mechman 250 amp alternator.
Voltage dropped as low as low 13's/high 12's full tilt at idle
Thanks, thats the kind of answer i'm looking for. I'm just pondering if this will be ok to bump at half tilt for 15 minute commutes on a single PM d3100 in the back with a d5100r up front. It's a stock honda civic alt. and I wouldnt be playing on it all day so i think the alt. would have plenty of time to charge the batt when I'm not bumping it. I also have a small battery charger I would be able to use at my house if need be.
arent civic alts like 70 or 90 amp? I personally wouldnt do it.
Andrew12
Honda.
Andrew12
Pinellas, FL
BigJoker
