SD-3 10 or E10 for this application?
AudiOn19s
Really wanting to try out a Sundown sub. SD-3 10 and E10 are the only options that will fit in my box.
Box:
1.0 cf PORTED pre-fabbed downfiring box under the seat of my GMC truck
tuned to 39 hz
Mounting depth of 6.25" cutout for magnet at this depth is just under 7"
I'm searching for better low end performance / output over the JL 10w0 I have in there now.
SD-3 - 10:
- I know it will fit
- designed for sealed only worries me about performance in ported box
E10:
It'll fit but it'll be tight.
Is 3/4" behind the sub for the vent going to be an issue?
I have about 1 1/4" of cleance from the mounting surface to the floor, will this sub hit the floor?
Input appreciated. I've always been a ported box guy, it's the sound the my ear likes.
What's the possible drawbacks to putting an SD-3 in a ported enclosure?
Thanks
Box:
tuned to 39 hz
SD-3 - 10:
E10:
Thanks
Your biggest drawback will be that prefab box... The subs will sound way better in a custom box... What year and cab is your gmc... I fabricated a 2" seat lift for my 04 ext gmc and it allows for ALOT more space and larger ports
mine is an 07-13 crew cab. The box is actually for the previous generation truck like your 04 but it fits and it's slightly bigger than most pre-fabbed for my body style.
I 100% realize the box is a limiting factor, but retaining rear seat functionality for adults is also a concern, as is use of the cargo space under the passenger side rear when i'm towing a trailer and need inside storage. Hoping to work with what I've got and make an improvement. I'm not a huge audiophile, I don't need TONS of bass, the combo I have in there now is really very close to what I'm after I just need a touch more low end and I'll be happy.
Going to either of these subs also allows me to go away from the 4ohm sub I have now and extract more power output from the amplifier which can be 1 ohm stable. The box will still choke it I'm sure but hopefully it's that little extra I've been looking for.
If not, then maybe I re-prioritize, raise the seats and build a custom box.
AudiOn19s
AudiOn19s
Columbus oh
AudiOn19s
