Idk, maybe you get different MDF where you're from than I get, but I'd have to disagree. Go take two pieces of wood, make a joint, let it cure for a couple days, stand on it with it like this: V, so that there is outward pressure on the joint. It will break (assuming its big enough to give you leverage), and it will most likely rip a layer off of the mdf on one or both sides of the joint
Now, in an actual box, one thing that makes it much more solid is the structural support of the other pieces of the box. when you've got wood connected with strong joints like this on all edges, the complete product is very sturdy, but the individal joints alone are not as strong as people seem to think, due to the ratio of the size of the boards to the surface area of the joints
