Screws?
2.5 inch drywall screws is what I use.
And you will split the shit out of everything...
I use 1 1/8" drywall screws if I am forced to use them. They are the safest as far as stripping and they will pull the wood in just as well as 1 1/4" screws.
Make sure not to put any screws within about 4" from the edge of the wood... it WILL split even if you pre-drill.
ok i think I'm gonna throw in my two cents.
Instead of drywall screws, which work great with drywall, get some wood screws. I'll let you choose the size, but I think that it would be wise to stay away from 2.5" monstrosities. I assume that you know you need to predrill.
The wood screws that I am talking about have a part near the head of the screw without thread. Drywall screws have thread right up to the head. The non-threaded part means that once the screw goes through the first board and into the second the head is pulling the boards closer together, without threads holding them apart. Here's a link to a pic of the screw type I'm talking about. Hope your box goes well.
http://www.tool-net.co.uk/data/tools/28csposs.jpg
My appologies I meant to type 1.5 inch drywall screws......2.5 would be overkill.
Here is a man that knows WTF he is talking about. Listen to him.
^^^Yep, but you need to find them with the unthreaded section as long as your wood is thick or countersink them to the point that the unthreaded part goes all the way through the first piece for it to do any good.
And if you can't manage to put a screw within 1" of the end of a piece of wood without it splitting, you're doing something wrong. You're either overtorqueing it, using too small a predrill or you're not using a countersink bit to countersink the screw head and relying on the screw to countersink itself.
THXdts
THXdts
Maryland
AudioAnonymous
