Scosche Wiring kit from wal mart?
I've also seen those kits. I'm about to get a wiring kit, should I use the Scosche wiring kit and save me some money or go with the Stinger thats more expensive? Would I be losing any power by going with the Scosche?
I recently purchased the $25.00 kit from walmart. It comes with (i think) 14 ft of 4ga, wtf Ill need more then that for the grounds. Why does it even come with 8ga?
I hope TommyK (
Nas
You will need more than 14 feet? What you are supposed to do is run the 4ga to the distro, then 8's to your amp, and run 8's for ground.
yep yep
thats the only reason why i didnt do another scoche kit was because there wasnt enough 4ga...
damm 14ft sux. i have 16ft and if it was 1inch shorter, itd be too short. mines in a halfcab truck too so its not a long run, so iono how u people with regular cars do it.
Gotta realize that these Walmart 4 awg kits come in two types, 1 for multiple amps, and another for a single amp. Obviously, the one for multiple amps is the one with a d-block and multiple 8 awg's, (hence the two set of RCA's that came with the kit). You can always double those up for a single amp or go out and get 2 feet of 4 awg wire.
Wrong kit. There's another kit similar and it uses 4awg.
I've seen the kit you're talking about though.
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
really?
been to multiple wal marts cant find the 4ga...
1200mk
1200mk
Los Angeles, CA
golfreak
