Scion tc daily driver to show worthy project
Getting everything ready for the big power upgrade this week
how many sq ft of deadener did you end up using to get that kind of coverage? Build looks awesome. Would love to hear those Pioneer midranges.
Thank you guys for the props. I dont need to sound deaden the gas cap as one the subwoofer is on the other side and ive replaced the factory lid with a heavier carbon fiber wrapped lid. wow i guess i ended up using around 200 sq feet ish... of JUST the foil covered stuff , i am not talking about the padding and foam.
Got the condenser in the car rut before it started raining and hooked up all the ground wires.
That's the ground for the shock tower or to the frame as my research indicated that goes directly to the frame .
This one goes to the valve cover bolt that goes down to the engine block
This one goes to the bolt on the side of the engine block by the alternator
This one goes to the ***** casing? It is in back f the starter if I'm not mistaken.
Tis is everything hooked up.. I also replaced the negative battery terminal with another JL Audio terminal. This is NOT the finished product as it started raining on me. I will neaten it up tomorrow.
I used a highly rated but in expensive auto ranging multimeter. The before and after are the readings before and after the buddy club condenser .
Test Before. After. In volts of course.
Battery. 12.38. 12.69
Alternator. 13.61. 13.44
Dist block. 13.18. 13.20
I don't have one that records over time unfortunately.
excelon72
excelon72
lafayette,nj
excelon72
