SAZ-4500D vs Audioque 3500.1
Id go w/ the saz-4500, Sundown has never let me down. As far as electrical, h/o alt, big 3, 2 runs of 1/0 and about 280ah worth of batts in your rear bank and a solid 60-80ah under the hood would be ideal
Yeah so now I guess its what price I want to pay! The thing is alot of people have told me that the difference might be seen on the TL but not for daily driving? Any truth to that cause the price difference is huge
this is a retarded comparison. are you seriously comparing a 4500 and a 3500? if you compare the SD3500 to the AQ3500.1 then it would be close enough to not matter depending on price.
Is it really though? On each of there sites they have about the same power at 1 ohm SD(4500) and AQ(4300) so im trying to figure out what each puts out at 14-14.4volts and if one will sound noticeably louder and electrical upgrade differences thats all
Sundown will do 4500 @ 1 ohm at 12 volts. You need 14.4 volts.
If you wanted to get 4K out of the AQ @ 14.4 volts then you need enough electrical to hold 14.4 which means you need 7-8 big batts and a new alternator.
i prefer the saz4500
ho alt 200 amp
good under hood battery , with matching rear bank of 2-3 more , of either of these for example (deka, kinetic, stinger, powermaster, shuriken)
big 3 in 0 awg
2 runs of power & 2 runs of ground from front batt to rear bank
then on to amp
would be a fairly stable set up for one
with car running of course
and add a mid and high amp as well you could also mooch of the above electrical as usually 100 amps of constant draw for that on full tilt
l DaChOsEnOne l
l DaChOsEnOne l
New York
350zspl
