Sold Sax50.4 and 2 sets of dd mids 6.5"
dbeez
looking for 340 shipped for it all can get some pics if seriously interested however my feedback is perfect..The mids have a slight dent in the dust caps but they work flawlessly..The 50,4 was bought in mid february and will com with an invoice for the warranty transfer..
4/3/2 Channel Bridgeable Class-AB Amplifier
MOSFET PWM Power Supply
Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
12dB Octave Electronic Crossover Slope
Variable Subsonic Filter
Independent 1/2 Channel High Pass Filter Variable with x 10 Range Selectable Switch
Variable 1/2 Channel Low Pass Filter with HPF/FULL/LPF Selectable Switch
Independent 3/4 Channel Low Pass Filter Variable with x 10 Range Selectable Switch
Variable 3/4 Channel High Pass Filter with HPF/FULL/LPF Selectable Switch
Independent 1/2 and 3/4 Channel Bass Boost Variable Control
Variable Bass-Boost Frequency Control
Variable Input Level Control
Input Sensitivity : 200mV ~ 6V
Subsonic Filter : 10Hz ~ 500Hz
Signal Input and Line Out RCA Connectors
Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
Tested Voltage & THD: 14.4V & Less than 0.05% THD
Operating Voltage : DC10V~16V Power Input
Wired Remote Controller
MSRP $349 USD
Rated power output
----RMS power, 4 ohm stereo
50W x 4CH
----RMS power, 2 ohm stereo
80W x 4CH
----RMS power, 4 ohm bridged
160W x 2CH
Signal to Noise Ratio >90dB
Low pass frequency crossover
50Hz~500Hz (CH1&2)
50Hz~5KHz (CH3&4)
High Pass Crossover
50Hz~5KHz (CH1&2)
50Hz~500Hz (CH3&4)
Variable Subsonic Filter 10Hz to 500Hz
Bass Boost 0~18dB
Variable Bass-Boost Frequency Control 35Hz to 120Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
THD@RMS Watts
Channel Separation 75dB
Fuse Rating 25A x 2
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 310(L)mm
The specs for the mids folks..
SPECIFICATIONS
Series
W6.5
Voice Coil Diameter
1.5"
Magnet Weight
28 oz
Power Handling RMS/Peak
150/400
Suspension
25mm
Nominal Impedance
4.0 Ohm
DC Resistance
3.1 Ohm
Model
W6.5
Rec Box (cubic ft)
0.5
Port Area (sq in)
8
Port Length (inches)
19
Woofer Diameter
6.5"
Free Air Resonance
36 Hz
Qts
0.33
Qes
0.34
Qms
8.8
Vas
21 L
Sensitivity
91 dB
Shipping Weight
11 lbs
dbeez
dbeez
crestwood,ky
dbeez
