Same brand amp for cabin and sub
RoachForLife
Kind of a weird request but Id like to keep my ride consistant and since Im redoing all the audio at once I figure this shouldnt be hard. Looking for the following specs from the amps:
Mono amp. 600w rms or so @ 2ohm
2 channel amp, 2x150w RMS
Was thinking of going with PG X600.1 mono and they have a 200.2 I think it is for the 2 channel. the multi channel is a little pricey so Im trying to see if there are any other combos you guys would suggest.
If it matters they will be powering a 12" JL W6v2 and a set of PG RSD 6.5 components.
Trying to get away with under $1000 for my entire setup including about $100 of dynamat. Wish me luck, haha =P
Thanks!
You are just going to get opinions, your best bet is to read as many reviews of amps that interest you as you can and then eliminate options as you go.
thing is, I want a starting point. As I mentioned above I was looking at PG amps, which I could do, the main issue being they are larger (my backseats are 14" and 22" long/wide). I was also considering JBL line of amps, but again, I dont know if they **** for subwoofer use.
Getting the same brand/type for both the sub and cabin probably wont produce THE best sound possible but id like to attempt to get the best of both worlds.
RoachForLife
RoachForLife
Florida
RoachForLife
