Safely discharging amp
A buddy of mine literally welded his screwdriver to the transformer in a Peavey CS-1200 that, till this day, he swears he discharged before attempting dis-assembly.
That's why really HV stuff still scares me a little...I used to take the "one hand in the pocket" advice for granted, until I worked on an RF amplifier with 3500V on the tube plates //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Anytime air starts becoming a decent conductor...//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
This is why I don't work on my own amps.
I've got a degree in Mechanical Engineering, so I have a bit of knowlege.....But that stuff just scares the living piss out of me.
Easy way is to just hook up ground and apply +12V to the remote terminal. Make sure you have nothing connected to the +12V terminal. Doing this makes the amp try to turn on, but without a power source on the +12V terminal, all it does is drain the internal capacitors and the amp turns back off.
Mynameismcgyver
Buford T. Justice
Mynameismcgyver
Long Island, Ny
midnightg35x
