Ok so here are the subs i am going to buy: http://www.crutchfield.com/p_070BP1204/Dual-BP1204.html?tp=112&tab=review
I need an adequate amp with 600 rms or so. It also needs to be able to work with the lights in the box. The dual amp you can get has a 12v dc input but its only like 100 watts rms.
How many channels would those subs use: 1 or 2?
Would an amp like this work: http://www.amazon.com/Pyramid-PB717X-1000-Watt-2-Channel-Amplifier/dp/B000E432TI
Also, do you know how to make the lights flash with the beat?
TIA I know i have a lot of questions
EDIT:
ok so i found the amp i want: http://www.sonicelectronix.com/item_11751_Crunch+P1100.2.html
The subs only use 1 channel at 4 ohms. I am going to bridge that amp to get 550 rms...PERFECT!
Now i was wondering if there is a 12 v adapter out there i could buy. I want it to hook up through the speaker wire so it pulses with the beat. I can not put the speaker wire in to the 12v spot because its DC. So if there is an adapter or some other way to do this please let me know.
Thanks
EDIT:
Thanks
