s10 wiring
I have a very convenient situation with my saturn, there is basically a plastic tube running along each side of the car, I simply took it off and put 4 runs of 0-gauge in each...couldnt have asked for a better setup really, a perk of the saturns //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
But doubt there is anything like this in your truck...i might be able to scrounge up some pics..
Right below the battery there are two holes to run in the frame. This is how I ran my ground, if you run your power wires through make sure to use something to protect the wire from rubbing on the hole. This is on a 2001 s10 blazer (the front half of the frame is the same as the trucks) with 2/0 welding wire.
i bought a drill from lowes, and a 1" bit. Drilled out a huge hole in the firewall on the passenger side, then took them both back to lowes //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
17feet got a positive to battery AND negative to battery that way. If you're slightly short on money, this is where you can scrimp.
SamC
FI CAR AUDIO!!
SamC
Baltimore (Glen Burnie, MD)
Tehgregzor
vegang
vegang
