S10 reg cab box help!
Skadoodat
Alright, so I'm planning a build for my S10 reg cab, and need help designing the box.
It's going to be 2 SA-10's in a 2 cu. ft box net, ported, tuned to 33-35 Hz. Also powered by a SAZ-1500.
My max dimensions are 50"L, 22"H, 9"D bottom, 5"D top.
I made up a box using the torres box calculator, but I was having problems with the port.
I'm planning on using aeroports, but they were needing to be too long for that tuning in a small box.
Not sure what diameter, and how many I would need.
If anyone can help me out I'd appreciate it!
I would go 2.4 with 2 4" aeros. side fire the ports to the passenger side. Don't go the full 50" wide if possible. Not sure if all that will fit properly but you can hit me up for a design if you need help.
you act like the military will just lock up anyone and everyone... there are guys at gitmo that need to be there, and there are numerous individuals who have been released... not saying that your freedoms aren't being stepped on, cuz thats been happening for a LONG time... but its not like the gustapo is rolling into town, and you can get rid of that neighbor you dont like just by claiming he's a jew... just a little perspective
Well I emailed sundown audio, and they told me 2cu.ft was perfect. Or should I go a little bigger? And is firing the ports to the passenger side better than drivers? I've just read drivers side is better. And I just put 50" as my max cause I wasn't sure where id fire the ports. But I know there's gotta be at least 4" from the wall.
Skadoodat
Skadoodat
Macomb, MI
Skadoodat
