RyanM923's 21" Autotek Build...
RAM_Designs
SketchUp Master
21,735
Rockwall, TX
So I'm planning on starting a box for my 21" Autotek sub that I've been trying to sell for the last few months....I figure since no one wants it, I'll just use it. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Maybe if I put up some good numbers with it someone will want to buy it. //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
The box is going to be 10ft^3 tuned to 53hz, with about 250in^2 of port. It'll be powered by a Sundown SAZ-1500D at .5ohms in my '04 Dodge 1500 4-door truck...here's a little glimpse as to what it's going to look like.
This will all be below my window line, also. //content.invisioncic.com/y282845/emoticons/sneaky.gif.7189749b3a3f769e8815b47e8ae87f88.gif
just do bassrace and lower the tuning.more impressive.
There's no bassrace stuff around here that comes around more than a handful of times a year. If there were I'd stick to my MJ's for comps.
i'm pretty sure people don't want to buy it is because they can't fit it //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Actually, for a flat response curve winISD plots it at 2.6ft^tuned to 36hz, hence why it's called the "Stealth" line. I'm just going this big an tuning high for a big peak in the response curve.
Well I decided to change my box a little and use some leftover MDF from my other boxes. The box will now be 8.5ft^3 tuned to 52hz, and just 49" long. Got started on it tonight...
First pic came a little late in the build...
A little size reference, the box is 9.75ft^3 total.
Got some bracing in...
Tomorrow I'll be doing more bracing, putting 45's in the corners, and getting the front baffle all nice and pretty...more pics to come. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
RAM_Designs
SPLBassJunkie
    May 21, 2024
    May 20, 2024
