First, install/mount your two rear batteries.
Wire them in parallel. Use a small 1/0 jumper cable and wire the positives together and the negatives together. Now they are essentially one big +12v battery with double the current capability of an individual equivalent battery.
Ground the rear batteries, I personally recommend a solid frame ground and a solid chassis ground. Run you two 1/0 positive wires from your front battery to the input of one of your rear batteries. Make sure to fuse the output near the front battery AND the input near the rear battery. I recommend using ring terminal fuse holders, so you can fuse both wires at the same time...
nG
