yea i know i thought about that but having the subsonic and low pass off alittle bit was my concern about that. didnt know if it would affect a whole lotOr you could just gain match them with a DMM or clamp meter. Not rocket science
not sure what you mean by this sorry little explanation?Better watch out. Not to try strapping them with the maxx link. They are already two amps in one. From what everyone says they are two of 1500d ones in one shell.
Use the maxx link a normal bass line driver.
Well the max link is know for strapping amps. That do not have a master slave switch. Still not all amps work though witht he max link. Also. I am not fully sure. But you can not use it to strap two amps that are already two amps in one. The audiopipe3000. Is two amps in one case.not sure what you mean by this sorry little explanation?
To clear it up more. Like its already strapped internaly in the amp. Two boards amp in one case.the audiopipe isnt 2 amps in one..its 2 boards yes...but as long as you are running your final ohm load at 4 or above...it would work just fine
