Running speakers through switches
bdawson72 ...that pretty much it. I want something that u wont find/very rarely find in any other system and i want to be able to not fiddle with settings to do this...just a flip of the switch would be much more convinient. Thanks for the responses guys
a remote volume would have the same effect without interupting the current path.
Yes it would however the potentiometers are only suited for one controlled circuit output, so he would have to have 2 seperate volume knobs, 1 per speaker. Unless there is products out now that 1 knob resists 2 indpendent circuits, but I don't think there is.
it's called a remote volume knob. it is TWO pots on one shaft (crazy huh!). done A LOT for in-home wiring. They are not small nor cheap and are duty-rated by watts.
IF he could handle RCA level fading, there are universal gain knobs out there. Next would be a velleman kit for something like that. Last choice is a DPST switch. (first would be the FADER)
I tried this once when I was in high school. I wanted to be able to turn all my speakers off so that I wouldnt blow them up when I burped in the spl lanes (speakers were powered by the head unit). I tried hooking up a switch to each speaker, but some (distorted) noise still got through the switch when flipped off. I'm not sure why/how... Nevertheless, switches on the speaker wires is not a practical way to go. Just fade it. //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
It's probably the A/C voltage arcing over the switch. Mostly you used a shitty switch that wasn't ment for what you used it for.
Not trying to get down on you, but that's probably what happened.
Pioneer~Saturn
Dr. Enclosure
Pioneer~Saturn
Dayton, OH
UndercoverPunk
