Running power wire for amp under car OK?
604Bronco
I have a 95 240sx and for the life of me I cant find a hole in the firewall to put the power cable through, i Know its there! however.. there is a hole in the spare wheelwell with a grommet so techinically I could run it under the car w/ wiring loom and zipties right? I read on a 240 forum and some people had done this. I think as long as its done right it should be fine, I mean there is wiring for the ******/diff etc,. under there done the same way right?
i did it with my last car, but it was 2 runs of 1/0 underneath //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
PS
If its the same body style as the one i has and i think it is... i know there is a hole there somewhere, i think i cut a new hole in a grommet in the firewall
It's almost always easier and faster to drill the firewall than run wiring under the vehicle. Seems like lots of people have a fear of drilling, but once you've done a few you'll get over it. Just find something on one side of the firewall that you can locate on the other side, like a cable that runs through. Once you're sure you're looking at the same bit of metal on both sides, then use a self-tapping screw to make a pilot hole. That way you don't have to worry about drilling through anything important if you're in the wrong spot. After you have your pilot hole and you're sure it's clear, use a step bit (unibit) to enlarge it to the right size.
604Bronco
604Bronco
Richmond, BC
KaeZoo
michigan born
    May 14, 2026
michigan born
    May 14, 2026
