running one amp 2 ohms an another amp at 4 ohms at same time?
I have 3 12s in one box 2 subs are running at 2 ohms want to add my other amp to the 1 sub at 4 ohms. My ? Is will mixing the ohms cause it to not sound clean cuz right now it sounds good but i want a lil more power an sense i have an extra sub an amp figured hey why not but not if mixing the ohms on the subs is gonna make it sound like crap....
Well i do plan on getting an all rockford fosgate system in the future but until then this is what i got to work with so running 2 subs at 2 ohms an 1 sub at 4 ohms is not a good idea? How come?
Just not a good idea in general..for so many reasons ...dont want to mix subs or ohm loads pick a set and run it ..and theres alot better stuff than rockford these days browse thru here and get a idea
wire 3x 4ohm subs in parallel to to achive a 1.34 ohm load.... do this and get yourself an amp that can run stable at 1 ohm
---------- Post added at 04:04 AM ---------- Previous post was at 04:04 AM ----------
what amp?
if you wire them in series, you'll get a 12 ohm load
trunkmuzik561
trunkmuzik561
west palm beach, FL
Side Show
