Running a monoblock in stereo?
Take the term "Bridge" out of your monoblock vocabulary. It doesn't belong there. There is no bridging, only wiring in parallel or series.
Dammit.
Aye, I knew I was using that incorrectly. It just allows you to wire the speakers using the amp instead of connecting the two speakers directly.
A monoblock with two inputs simply takes whatever you plug into the inputs, and combines them in a parallel circuit //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
As said before THERE IS NO BRIDGING THIS AMP.It is mono with 2 parrllel wired speaker inputs that have the same output signal.You can run all the + connections to just 1 input and and all the - to the other and it would be the same as if you used BOTH terminals.They are the same!
So, every "monoblock" i have owned has actually been a two channel...
I currently have the Fusion 4000D, which is basically two amps strapped(it has dual ground and power as well). My subs are D2, so i can either do 2 or .5 ohm...
So why can't I run each channel as stereo and run them each at 1 ohm? Because I would rather run ~2000 watts to each, but I don't have the electrical to run it at .5 right now. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
nice hair
The Fusion amps, like many others, have 2 hot and 2 neg terminals. Open the case and see, both hots are connected with a gold or brass strap, same on the grounds. This os for wiring convenience. Imagine trying to run 8 SVC subs off of 1 pair of outputs... Or using 8ga speaker wire going to a splitter, and you need 2 runs off of a single terminal.
And you have a helluva amp. If you get tired of it, donate it to my cause. "Audio for the poor in TN"
I is broke.
A mono amp simply connects the inputs internally.
What everyone has said is true when it is truely a monoblock amplifier.
Though, just a bit of information... when running a 2 channel... if running bridged (single load), is the equivalent of running each channel at 1/2 of that load. So, if you present the amplifier a 4ohm load bridged, it's equivalent to the amp as 2ohm per channel stereo.
nG
bunkerking09
Current Status: Win
bunkerking09
Kansas City, MO
loopkiller
