adulbrich
Olive oil un-virginer
Small black wire is ac hot and the small white one is ac ground. Big black wires go to a fuse block, then to the big red wires with the bolt for 12v+.i see a input hot/neutral and the outputs are obviously the larger gauge wire is you low voltage side. i see a black(ground) blue and brown.. **** test the coils windings..what power supply was that it had to have a bridge rectifier to turn it into DC.. you should get you a lil side project going.. lol you could bump you voltage up to 120v run some much smaller wire then know it back down to 12..
I'll use a multimeter to see which wires have continuity, and are therefore the same ones. Then I'll plug it in and see what the output voltage ratios are for the different windings.
