asilentfire
I just bought a JVC Arsenal KDA535 head unit and JBL P560C component speakers, and I'm looking for the best amp to power them while still leaving room for a sub and full range speakers in back.
Here are the specs for my JBL P560C component set:
Power Handling, RMS: 75 Watts
Power Handling, Peak: 225 Watts
Sensitivity: 92dB
Frequency Response (±3dB): 55Hz - 23kHz
Mounting Depth: Mid/Woofer 2-1/16" Tweeter 1-3/16"
Impedance: 2 Ohms
I want these speakers to get the full 75 watts RMS.
I was thinking of getting a 4 channel amp, bridging 2 channels to a sub and running the other 2 parallel through some full range speakers to the components up front.
This is my first system and I'm sure there are many things I don't understand, but please bear with me and correct me where I am wrong.
I am looking at 2 amps; the Infinity Reference 475a:
RMS Power Output (Watts x Channels) 75 x 4
Peak Power Output (Watts x Channels) 117 x 4
Power at 2 Ohms (Watts x Channels) 90 x 4
Bridged Power (Watts x Channels) 180 x 2
Minimum Impedance Bridged 4
Minimum Impedance Unbridged 2
and the Infinity Reference 5350a:
RMS Power Output (Watts x Channels) 50 x 4
150 x 1
Peak Power Output (Watts x Channels) 89 x 4
Power at 2 Ohms (Watts x Channels) 60 x 4
Bridged Power (Watts x Channels) 120 x 2
I would like to use the 4 channel 475a amp as I have a better price on it, but I can get either one fairly cheap.
I want to reach close to 75 RMS to the front speakers, and I'm not sure the 4 channel can do that.
My hope is that I can run the wire parallel through some full range speakers in back at around 60-75 RMS at 4 ohms and still have enough juice left over to give the front components 75 RMS at 2 ohms. I have to do this because I need the other 2 channels to power an amp.
The front components take power priority, I would be okay with the back speakers only getting 35 RMS if need be.
Well that's it, please let me know if the amp fits the bill,
THANKS!
Sensitivity: 92dB
Impedance: 2 Ohms
150 x 1
THANKS!
