Running 2 mono amps
bmwboyuk
ok i have 2 mono amps i want to power 2 12" subs can i use the sub pre out on stereo to input on 1 amp then use another rca from that amp on the out put to the input on the other amp
IM CONFUSED PLEASE HELP ME //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Yes, you run 1pair or RCA's from the HU to the "input" on one mono amp. Then you go from the "output" of said amp to the "input" of the other mono. Wire your +, - , speaker leads and remote and you are good to go.
boy your gonna wish you never asked me if i had any more questions
ok here goes when running cables down car i know that you cant run them all down the side together because of interferrance what cables can i put together and what do i have to keep seperate.
Its generally a rule of thumb to run RCAs and speaker wires down one side and power wires down the other (remote turn on would go with the power wires but it doesnt really matter much). Sometimes running them on different sides can't be avoided (well unless you wanna run like twice as much speaker wire).
And by earthing I think you mean grounding, I guess you call it that in England. You COULD run it to a distro block but there's not much of a point (waste of money too). Just ground them all to the same nut on your chassis.
bmwboyuk
bmwboyuk
LONDON ENGLAND
Redford
