Running 0awg in 2006 malibu
true, i may do that.. i just purchased this.
Cadence UDA0+4K 0/4 AWG Pure Copper Dual Digital Display Amp Installation Kit | eBay
i wont be running 2 amps atm, until i get another amp and new speakers. but should i just run the 0 guage through the car for now to the dist block in trunk, and leave everything else as is like the rcas and remote , until i add another amp ( weeks away )
i also purchased a ciggarette lighter volt meter.
I ran my 1/0 Cadence wire through the firewall (frustrating), then in the door floor panels (again frustrating since the driver side panel is having issues staying down, so for now its a little loose) as @mylows10 said run 'em under the carpet, extra step but in the end I'm sure its easier.
AGU fuses are meant for small current circuits. Because of this they can only support so much current and will blow if you try to push more than they are rated for. ANL fuses are much better for the job because they can be much larger. Mini ANL fuses will work as well and are good up to 150A.
it says in description its anl... hmmmmmmmmm
even in the pic of the box it shows anl
and 100agu is actuallywhat im runnin right now haha, had to get it off ebay.. till i upgrade to this
cbuts
cbuts
canada,ont
cbuts
